Don’t be sorry 🙏 I understand at 55 it will possibly always be with me now. You can only try though hey ! And it’s far-far from debilitating. More like I’ve sat on a few fingers for a while…….
As much as I pretend the problems, potential changes, hardware swaps irritate me - I also like having a goal, a target, something to do, to try to achieve. So this weeks mini project is ‘Feel the fingers’ 🤣
I'm 72 and don't suffer from this or any similar aches and pains because I've adjusted my position as my body ages to address any discomfort that raises its head. I've done this alone and with professional help. You absolutely should not accept that's just how it is now. 55? You're young.
I've genuinely tried to follow the thread from the start this morning without success. That's my fault. I'll offer two comments. The bars in your most recent image look, to be blunt, ridiculously wide. I'd expect to encounter a lot of discomfort in the position I imagine they give you. Seven hours on the DD must have been very uncomfortable.
Second I genuinely worry those adaptors you've added significantly reduce the control you have over the bike, far too narrow.
Sometimes professional help is the only solution. At the opposite end of the body the soles of my feet began to ache badly around the second metatarsal. I spoke to a podiatrist.
The diagnosis is I have arthritis in the first metatarsal preventing it from functioning correctly. This transfers excessive weight bearing on to the second metatarsal causing it to inflame and ache. A support in my shoe to tip the foot towards the first metatarsal reduced the weight bearing and solved the issue literally instantly.
I doubt I would ever have conceived of this let alone fixed it inside five minutes. You pays your money..........
