Right hand going numb when riding…..
PaulSB
As an aside on the bar width aspect of this. As I have grown older, in years only, over the past ten years I have narrowed my bars considerably. My recently purchased road bike has 37cm bars, these are far more comfortable than my old road bike. I'll be converting this to 37 before winter, her new role. My gravel bike is wider, I think 39/40 but need to check, and I need to consider if 37 would be suitable for this bike - I'm a little concerned by the control aspect.
On the new bike, 37 cm bars, the shoulder and neck ache that was beginning to build has disappeared. I have reduced the stem length as well.
Deeferdonk
I have a fitted a Redshift shockstop suspension stem to a gravel bike and find that i don't get the same hand buzz that i get riding my bikes with a rigid stem. (possibly an expensive solution but if interested its worth getting on the redshift mail list as they seem to have Sales every so often)
sevenfourate
sevenfourate
Devotee of OCD
I'm 72 and don't suffer from this or any similar aches and pains because I've adjusted my position as my body ages to address any discomfort that raises its head. I've done this alone and with professional help. You absolutely should not accept that's just how it is now. 55? You're young.
I've genuinely tried to follow the thread from the start this morning without success. That's my fault. I'll offer two comments. The bars in your most recent image look, to be blunt, ridiculously wide. I'd expect to encounter a lot of discomfort in the position I imagine they give you. Seven hours on the DD must have been very uncomfortable.
Second I genuinely worry those adaptors you've added significantly reduce the control you have over the bike, far too narrow.
Sometimes professional help is the only solution. At the opposite end of the body the soles of my feet began to ache badly around the second metatarsal. I spoke to a podiatrist.
The diagnosis is I have arthritis in the first metatarsal preventing it from functioning correctly. This transfers excessive weight bearing on to the second metatarsal causing it to inflame and ache. A support in my shoe to tip the foot towards the first metatarsal reduced the weight bearing and solved the issue literally instantly.
I doubt I would ever have conceived of this let alone fixed it inside five minutes. You pays your money..........
Thanks for your thoughts.
Bars are wide agreed. We’ve identified and will work on (Further) when back from vacation. As discussed (Elsewhere here ?)…..that may involve reducing the fleet / buying new equipment or bikes / getting fit / only having maybe 2 similar and fitted bikes; instead of 9 ‘random’…….
From that - I bought the inner handles as an immediate, cheap, easily reversed trial. They are 350mm apart at the gripping face. And that is the maximum I could go without the clamp of those interfering with the housing of the gear change levers both sides.
To have the option of a change in hand / body position was great on the last ride. Width felt different for sure ! Not unholy and outright dangerous by any means….
sevenfourate
sevenfourate
Devotee of OCD
A follow up:
Heading toward 2 months on and a few changes have seemingly made my R/H finger numbness 90-95% better 😁
1. I do reasonably regularly stretch / massage / vigorously move the ring and little fingers (2) that were being affected.
2. I bought and am using some much higher quality (And much more thickly padded) Castelli gloves. As much as I possibly still prefer the initial feeling of a thin glove - that’s no help if 20 miles on you lose all feel anyway 🤨
3. When on a decent straight bit of road; I swap from the proper grips on the ‘flat bars’ - to the much narrower inner handles. Affording me a much better hand width / position. And a change; to break up being on the grips for hours on end if nothing else…..
**And I say 95% better; because as much as the numbness hasn’t crossed my mind at all (?) while riding (Longest ride being 55 miles since my original post on 11th August); I am aware sitting here now there’s a very slight difference in feeling between right little finger and left.
BUT: Moving on; and soon I’m aiming to be doing a lot of riding on my drop-bar’d bike.
Has anyone (successfully) chosen a bar tape based on vibration reduction. And if so - what was / is that ?
