I would remove the tyre and tube and try and bend the rim back into position with some pliers.
Absolute nonsense.No my friend, that's split right on the weld. You can't just bend that back because it's split, which means if you did bend it back over it'd just cave in again the second a brake pad runs across it and more than likely lock up your wheel and throw you off. That's spent i'm afraid!
I think it's a rear wheel.If you find the brakes grab as it rotates, you might get a better result by flipping the wheel round, thus reversing the direction the dent hits the brake block.
Good point, well made. <tolchocks self round gulliver>I think it's a rear wheel.
Viddy well, droog.Good point, well made. <tolchocks self round gulliver>
It might not set your Y fronts ablaze with excitement, but from what little we can see of it the wee beastie looks clean enough. Hopefully that wheel can be sorted, but if not it must surely be worth a tenner on a used wheel.
If it were mine it get on a bench vice with the soft jaws.
