e-rider
Banned member
- South West
I've just built a new rear wheel using a Rigida Chrina rim.
The rim joint is quite bad on this rim. The brake surface is smooth because they are machined after the join is done, but looking down on the wheel when in the jig it's impossible to remove a 'kink' at the joint when the wheel rotates. Most rims have this problem a tiny bit but it's usually un-noticable.
My question is: will I notice this 'lump' when cycling? Probably not right? It's about a 1mm ridge at the join. I have tensioned 1 spoke more than I would like to minimise it so I'm not going to crank-up the tension anymore to bring it down further!
