Rim tape
jowwy
Can't spell, Can't Punctuate....Sue Me
Advice needed - is it ok to run 22mm rim tape on a 23mm internal rim width??
si_c
Wirral
I would have thought so, once it drops into the rim bed, the effective width should drop - I'm using 19mm wide rim tape on a 18mm rim, and it's been fine.
Edit: I should note that I'm using velox rim tape which is a bit thicker than most as well.
Milkfloat
An Peanut
Midlands
Personally I use gorilla tape for everything, tubeless or tubed, I can cut it down to whatever width I like. I generally do two wraps.
