PeteT
- Kingsteignton, Devon
I much prefer bib shorts to 'ordinary' shorts, but tend to wear the latter as it's too much of a faff if you need a pee with bib shorts - at least with ordinary shorts you can jump behind a hedge at the side of the road and just pull the top of them down & don't need to remove your jersey etc! Unless....is anyone aware of road-style bib shorts that have the equivalent of a fly hole?
Ta.
Ta.
). Hence, I can't pull the bib shorts low enough at the front to pee over - and the legs are both long (just above knees) and very tight, so I can't go down the other route either! I've met a couple of folks with similar problems. Was just wondering if some enterprising soul had reached a solution....
