scotsbikester
I'm trying to raise the bottle cage on the down tube, in order to make it possible to mount my U-Lock within the triangle.
I've already fitted the SKS riser thingy. But it's not quite enough. So I'm looking for a bottle cage where the lowest mounting hole is as low as possible. The one I've got currently is the M-Part one.
The lock at the moment collides (just) with the corner of the cage, and the bottom of the bottle itself.
If I could at least get rid of the lowest part of the cage, that would be good, even if it meant I couldn't take lock and bottle at the same time. So I'm looking at cages with this sort of design, cutaway cage and lip to hold the bottom:
I like the aesthetic of this (my bike is a fairly tradition steel framed tourer, fitted with Brooks/Nitto/Carradice etc.):
https://winstanleysbikes.co.uk/ritchey-classic-bottle-cage?
Though I'm not so "style orientated" that I'm going to reject something like this:
https://www.topeak.com/global/en/product/1463-NINJA+-CAGE-Z-WITH-AIRTAG-MOUNT
The main thing is that the holes are as low as possible. Which will enable the combination of U-Lock, bottle, and frame pump which is proving at bit tricky.
Suggestions welcome.
