spen666;45025][quote name= said:but people can see you. Not so good down a dark un-lit path as they are more a 'be seen' rather than a 'see' light set up. Plus they're small enough to whip off and stick in your pockets if you need to.
[/B]starseven said:Its reduced in the local Blacks I would imagine these things are not done at store level, so other Black will have it reduced too.
I have a box of old reflector brackets that can easily be cobbled into a bracket often LBS will sell you some they have lying around for pennies. Most people Im sure can fasten a torch to a bike in some way or other. These are pretty compact about the size of a wipeboard marker.
Chuffy said:... the Dinotte 3w rear but that's over £100 and possibly too bright if you angle it badly.
Hairy Jock;45655][quote name= said:too[/I'] bright if you angle it badly.
What do people think of this for a cheap, 3w led rear light?-
http://www.maglite-torches.co.uk/index.asp?function=DISPLAYPRODUCT&productid=107
http://www.maglite-torches.co.uk/index.asp?function=DISPLAYPRODUCT&productid=156
http://www.maglite-torches.co.uk/index.asp?function=DISPLAYPRODUCT&productid=134
this[/url], for less than a fiver.
Christ man if you've got money to burn please give it to me I could make much better use of it!
so... what's the rest of it for then? Presumably you're paying for the 'whole kit'?bonj;45273][QUOTE=Cunobelin said:Bonj,
the photo shows the whole kit, in practice you use only the light, and the small black battery pack. more compact on the bars than a complete beattery enclosed unit.
[/URL]
