Pointy boy
Had one of those easy jobs that turned into a frustrating marathon yesterday. Fitting new gator skins and tubes.
I've fitted loads of mtb tyres before, but this was my first time with 700x23's. It all went smoothly except getting the very last bit of the tyre seated properly on the rim. I always work towards the valve, so this was the last bit.
I could get the tyre onto the rim, but there was a slight bulge adjacent to the valve. It seemed like the reinforced bit of the inner tube where the valve is attached was preventing the tyre from seating properly. After multiple re-fitting attempts, plenty of swearing and general mucking about ( wrecking one tube in the process) i finally got it neatly seated. My question: is this a common issue, and if so is there a knack to doing this? Was I doing something wrong?
The tubes were Continentals, and were the correct size for the rims.
Thanks.
Thanks.
