dudigrinfeld
Anyone can address what stiffer and lighter between the 2? After all with rotor press fit caps you can use both on a frame with bb86 shell. What would you go for and why?
Thanks
Thanks
I would get the 3D+ so I could swap it between both of my bikes with ease without adapters.
As for lighter, check the specs, they will tell you. Stiffness wise, probably not a lot in it.
