Roundabout Left Hook
phaedrus
Going home around 4.45 last night, I'm in the inside of two lanes coming up to a roundabout where I intend to take the second exit (straight ahead). 30mph area. Pedestrian barrier on the pavement. Fairly busy traffic conditions. I'm in primary.
An articulated lorry flies past me, almost touching me. He's mostly in the outside lane. While he's about half way past me he indicates left, slams on the brakes, and starts to turn into the first exit. Everything goes into slow motion. I look at the side of the lorry coming towards my right, and the barrier on my left. I hit the brakes as hard as I can and throw the bike to the left. The rest of the lorry whizzes past, just missing me, and the rear wheels mount the pavement just where I would have been. My heart was pounding in absolute terror.
The only detail I can remember is that the lorry had an Irish number plate, which is pretty common around here. MN 04 something. I'm a very placid person, but I believe I would have been capable of serious violence towards that lorry driver. :ohmy:
thomas
the tank engine
Woking/Norwich
Sounds nasty! Close lorry passes are horrible just because of how massive they are!
dellzeqq
pre-talced and mighty
SW2
Jim - that's terrifying.
The awful thing is that it was your experience that saw you through - the next cyclists might not react as quickly.
XmisterIS
Purveyor of fine nonsense
I'm not defending the lorry driver here - it sounds like he should go back to driving school ...
BUT ...
Those cabs are so high and wide that if you were on his left-hand side he may not even have seen you. I've driven a lorry before and it is really hard to see immediately below the left-hand front wing - that being said, he SHOULD have been anticipating the road ahead - its called "due care and attention"!
Incidentally, do you wear anything hi-viz to catch the motorist's eye?
Wigsie
Nincompoop
Kent
Mate that is messed up!! glad you called on your ninja training and managed to avoid a serious incident!
Go out and buy a lottery ticket and a nice cold pint or twelve!
Jake
scarey stuff, good job your aware of whats going on around you as could have been much worse.
not much of a comparison...... but when i pull up to a junction on the inside in a cycle lane, and the traffic is staionary, i check cars indicators. However, i notice that most if not all black cabs decide to turn left at the last minute and right hook you, then make out its your fault because your on the inside grr
Joe24
Nottingham
Ahhh, Irish turck, that explains it all;)
The thing that pisses me off with truck drivers, is some of them will put you on their left, like when coming up to a round about and they are going straight on, the put you on the left of them. Which is something i hate. i dont like being sat down the left side of a lorry at all.
And yet, they all moan that cyclists go down the left hand side at traffic lights.
Its basicly when its good for them. A so called proffessional driver should be able to anticipate and not have the cyclist down the left hand side i would think.
Most Irish drivers are dodgy anyway, the big engine and lack of limiter................
phaedrus
phaedrus
BUT ...
Please read the post. He came from behind me while I was moving. Hi-viz? The visibility was as good as it can get.
He was in a hurry, and I was in the way.
Crankarm
Nr Cambridge
Frightening. You had a very lucky escape. Your heightened anticipation and quick reactions undoubtedly mean that you are still with us to write your tale. Glad you are ok.
CCTV per chance? I would contact plod. It might have been a stolen lorry.........
Chances are that had he wiped you out he would not have stopped :biggrin:.
I had a green and white 8 wheeler 30 tonnes aggragates lorry of KERRY PLANT HIRE run me off the road Duel style last year. Like you, just after, I looked at where the lorry went and where I would have gone had I not taken evasive action to save my life then I would have been truly DEAD :laugh:. In my case the truck left deep tyre tracks on the grass verge adjacent to the road, over which I jumped into a drainage dyke with my bike - a touring hybrid with panniers and not a light jump bike or MTB, and realised had I remained on the road I would have been well and truly flattened. The driver had previously nearly killed me trying to pass me, took umbrage when I shouted up at his cab, rammed me into the side of the road, stopped, got out and tried to assault me. But he didn't feel lucky when he saw my Abus Granit X Plus D-lock poised to strike his head so he backed off and waited up the road as in Duel for me to pass by some 20 mintues later. Truly frickin terrifying. And plod in Peterborough was not interested. Although I recommend you report it to your plod, they might take incidents such as these more seriously than Cambridgeshire Police, but they might not.
A shower and clean under wear was in order when you got home I should have imagined.
