Kayjay
Regular
- Merseyside
Hi, any advice for best route planner suitable for road bikes. Thanks
cycle.travel is fantastic! Using it has resulted in me having hundreds of hours of stunning scenic rides on quiet roads and lanes.cycle.travel but I run it, so might be a little biased! It’s designed to find quiet routes and uses real traffic data to do so. Any offroad sections are highlighted in green so you can drag the route away if you’re on skinny tyres. Always happy to hear feedback/suggestions.
I use a mix. But if it's an area I don't know, I like Strava's one (which is still beta). It uses the rider data to show you where cyclists prefer, and has given me some brilliant routes. Caution if you are anywhere near a mecca, like Box Hill. It tends to route you towards hubs. But generally, it's pretty good.
Doesn't it only show you where Strava cycle users go? In my experience, that means that anywhere with decent cycling infrastructure and numbers, it'll be biased towards busy but fast A roads even when there's a perfectly good 20mph rail trail, greenway or quietway paralleling it. Good if you're the sort to blast it and never mind the trucks but not my cup of tea.I use a mix. But if it's an area I don't know, I like Strava's one (which is still beta). It uses the rider data to show you where cyclists prefer, and has given me some brilliant routes. Caution if you are anywhere near a mecca, like Box Hill. It tends to route you towards hubs. But generally, it's pretty good.
I realised the limitations of mine when finding myself needing to make two right turns across a busy A road (or ride 50m along the wrong side) that were completely avoidable with better route planning!I just go with my senses and hopefully my basic navigational instincts
