TheLondonCyclist
Stick food in containers and store outside this winter.
You are Me and I claim my £5!Have a secret 'thermostat war' with your family (I've widened the discussion to gas, so as not to be fuel-discriminatory)
) . You turn it down a degree or two at every opportunity. When you are out, they whack it back up. Then on your return, you lower it again.
My older sister has her heating turned up way too high (thermostat set in the 20s). I told her that it was too warm. She denied it. I asked if she had the heating on in the summer? No - of course not! I pointed out that the average summer temperature in England is about 15.6 degrees so her home is often 5 or 6 degrees warmer in the winter than in the summer. Where's the sense in that!Have a secret 'thermostat war' with your family (I've widened the discussion to gas, so as not to be fuel-discriminatory)
PS Save time and energy by only boiling as much water in your kettle as you need. That's another thing my sister gets wrong - she'll spend 5 minutes boiling a full kettle to make just 1 hot drink.
event though.trying to get the kids to turn lights off though is aevent though.
Get some LED bulbs, they're great! Just make sure you get ones with SMD's (surface mount diodes) as opposed to the older 5mm bulb shaped LED.
I bought four 4 watt LED bulbs to replace four 40 watt halogen bulbs, and they're just as bright. They cost around £15 to £20 from a UK seller on eBay, great deal!
