Seeking Hand Sprayer Recommendation
hoppym27
I'm looking for a hand sprayer to assist me with cleaning my bikes. I am looking at one of the hand pump jobbys and not a jetwash, like the sort in B&Q they advertise for insecticide spraying.
Is that the sort that will work, any advice?
The range.... £8 does exactly as it says on the tin, ive got one..
https://www.therange.co.uk/garden/hose-pipes/irrigation/garden-sprayer/
screenman
The more you spend the better you get in my humble, Hozelock seems to last the best around the garages, even spraying TFR and wheel cleaners.
Randy Butternubs
Yeah Hozelock stuff is generally good. Also bear in mind that the more airspace you have in the bottle the more pumping it needs to get up to a good pressure but the longer it will last without needing to pump again. For this reason you might want to get a large one and only fill it with as much liquid as you need.
johnnyb47
Wales
I to use a cheap garden sprayer to keep the bike clean. It's does a brilliant job at blasting the crud away. I find most effective to do straight after a bike ride when all the muck is still wet.It just washes away better.
