eddieallen72
Member
I’ve recently fitted a Shimano Alivio Shadow rear derailleur to my steel touring bike and I’m having trouble getting the upper (guide) pulley close enough to the sprockets. The setup guide says that you should aim to get the upper pulley around 5-6mm from the sprockets but I can’t get it anywhere near this. The b limit screw is all the way out but it’s still a mile off, and causing sloppy shifts when moving from larger to smaller sprockets. Anyone else had this issue?
