Sheared seat post bolt - why?
I recently replaced my bike saddle. The fixing is shown in the attached photo. I found that it would not stay tightened once I began riding, and would work loose within a minute or two. I could see nothing wrong. I took it apart and re-set it in place, which seemed to work for a while but after a week or so it began working loose again. Today the bolt sheared off while I was riding. This happened to me on a different bike a few years ago. I'm not heavy. What might I be doing wrong to make this happen, and how might I ensure it doesn't recur?
All uphill
Still rolling along
Somerset
I guess that it sheared because you were using a lot of torque in an effort to stop it coming loose.
My other guess is that it loosened because it is a flimsy aluminium clamp being stressed to its yield point.
But I may be wrong. Twice.
Cycleops
Accra, Ghana
As above. That hi ten steel bolt is screwing into soft aluminium so has stripped the thread with too much torque . You need a decent seat post clamp, preferably not a pretty red aluminium anodised one.
Ajax Bay
East Devon
Let's see a picture of the OP's actual saddle post clamp and the sheared bolt - not some internet image.
Surprised not to see ridges on the curved surface - and the curve seems 90 degrees 'wrong'.
And the make of the seatpost?
I can't believe the small bit (effectively a nut) the steel bolt screws is made of aluminium - edit: but I've just checked a similar one of mine, and the 'nut' on mine is Al.
Gosh! That's made my day.
I was waiting for all you knowledgeable people to come along and tell me why I was wrong!
Nope, you was correct. Never had a seatbolt snap myself. Yes creaks and groans, needing a good clean and grease again.
ColinJ
Puzzle game procrastinator!
I snapped one once, probably for the reasons suggested by @All uphill. I had to ride home standing up, with the saddle in my back pocket. Fortunately, it happened on a hill above Hebden Bridge (where I lived at the time) so it only took me a few minutes to get back.
Gunk
Oxford
Just replace the square aluminium captive bolt with a regular nylon steel nut and washer, only problem will getting a spanner to it.
Loch side.
The bolt didn't shear. It broke off from a stress crack that developed at the root of one of the exposed threads on the bolts in an area between the start of threads just after the smooth, unthreaded part of the bolt and where the threads in the nut (red aluminium nut) starts.
It is important to not use the term shear loosely, if you want to understand the mechanism of these breaks. Imagine you have a peeled banana. Now grip it with both hands so that your fists are touching each other. Now push the right fist away from you (keeping it parallel to the other fist) and simultaneously pulling the left fist towards you, keeping it parallel to the right fist. That is a shearing action. You can also do a torsional shear by rotating a fist or both fists in opposite directions.
What happened here is not shearing. A single-bolt seat clamp like this, with two wide clamshells holding the seat rails captive, develop a prying action as you move around on the seat and force the seat nose up and down. This prying action bends the bolt backwards and forwards. A crack develops at the weakest spot (the sharp root of the thread) and develops inwards, breaking the bolt.
It is a design problem easily avoided with a two-bolt design that eliminates the bending of a single bolt in the centre of the see-saw and transfers the flex to the seat rails instead, which have no weak stress risers and take the flex over a longer distance.
