Trigger369
Hi folks .
Anyone have there sheds /pain caves insulated? I'm looking to insulate mines and looking the best way to do it .
It's a 10ft×8ft with a peaked tin roof .
Roof has roofing felt under tin. Walls are 18mm t&g with roofing felt sandwich between the t&g and frame. I was thinking of using foil bubble wrap on the inside then a batton on top of foil and add Osb to the batton giving a air gap on either side of foil . On the floor use the foil underlay with laminate floor to finish. Whats your thoughts.
