irw, I think see the perspective thang, the normal-sized back door is down two steps which are not obvious in the pic. The shed is 2.7m square and 2.5 m high at the highest point. It houses a walk-in fridge and the lump is a covering the refridgeration unit.Somethings not quite right about that picture...either you've got a really really small back door, the perspective is exceedingly deceiving, or that's one mahoosive shed! What's the extra bit for?
Can I ask how it cost to make it yourself?
He probably has another shed with a compact crematorium inside.A domestic walk in fridge?????? That's sooooo much cooler than burying the bodies under the patio...kudos that man......
He's already put the bodies underneath it ... this way it will be much harder to move to find the bodies so they won't bother looking!A domestic walk in fridge?????? That's sooooo much cooler than burying the bodies under the patio...kudos that man......
For the shed, excluding labour, the cost would have been about £500
Now i get the perspective that's mahoosive!!!Can i ask should the vents for the heat exchanger be obscured by timber as i would/wood have thought that they needed to be more open ?
