Shimano di2 front dérailleur
Andyrums
Hi guys
I have a trek domane with di2 and love the shifting,however,the front dérailleur struggles going from 34 to 50 sometimes and not sure why,could anyone give any suggestions?
I have adjusted the upper and lower limit screws,got the cage to the right height and also made sure it's parallel with the front chainrings
Thanks!
raleighnut
How far are you down (or actually up) on the rear block when you try to shift.
I am running a compact front with ultegra DI2 and just recently my front has started to take a bit longer to shift into the big ring, I think it may just be that the ramps are worn on the big ring as they have done a fair bit of mileage now.
Andyrums
Andyrums
Well it seems to happen around the middle of the rear cassette,but then other times there seems to be no issues
