Nigeyy
- Massachusetts, USA
So recently was installing some new Shimano lower end hydraulic brakes. As I'm paranoid about over tightening things, I shortened the hose, put in the joining insert and olive and screwed it in, but trying not to over tighten it.
Well, the brake lever would initially hold pressure, but then slowly you would feel the lever go all the way to the handlebar. No problem, I thought, I'll just bleed it, so I did...... 3 times over with the same result (should add, I'm experienced at bleeding Shimano brakes). At this point, I was really considering it was a bad brake with seals letting fluid go past -I mean, no brake fluid was leaking out anywhere, and the lever was going to the handlebar after initially feeling firm.
It was then I noticed that the amount of threads left visible where the hose connects to the lever assembly compared to my other brake was considerably more, so with much caution, I tightened the hose even further.... and voila! The brake was back to normal, perfect!
So my question is: how did tightening it fix this issue? When I depressed the lever, wouldn't I expect fluid to be leaking out? The complete absence of brake fluid leaking out anywhere really made me suspect the brake itself was bad -and without a shadow of a doubt, tightening the connection completely fixed the issue. I'm trying to visualize how the brake works -I always thought in hydraulic brakes increased pressure in a master cylinder to the activate the slave cylinder was the way it worked -and as such, if there was a poor connection, fluid would leak out allowing for the piston to depress, much like what I was experiencing.
Anyone with any explanation as to why this is?
