Deleted member 1258
I have sram rival on my verenti, it just works, I've hardly had to touch it.
That is the very reason I would never touch SRAM. It was bad enough getting used to Shimano where the lever behind the brake dropped you down a sprocket rather than onto a bigger one like I was used to after years with Campag.SRAM's Avid brakes are really crap. Difficult to bleed, noisy and uses DOT fluid will all it's associated problems instead of oil.
Edit: And how can I forget the that rubbish GXP crank/BB of theirs? The left bearing has the longevity of a mayfly in a snowstorm.
Edit again: My memory is really coming back now that the nightmare has been awakened. That double-tap system on the road bike where when you're on the largest sprocket at the back and think you have one more to go and tap it, it doesn't just refuse to budge like all decent systems with a good Japanese or Italian pedigree. No, it actually shifts down, the last thing you really want when you've just tried to shift up.
And, aren't they the perpretrators of Jagwire as well, wire coated with rubbish Teflon that rubs off within a week and then turns sticky?
Shimano not as agricultural as SRAM, particularly in the lower end stuff,also spares much more readily available from shimano.I've been looking at mountain bikes around £750 and one or two have Sram gears.
Is there any good reason to avoid them in this application?
For a podgy middle aged bloke like me wobbling along trails I doubt it matters which company makes the groupset.
But is maintenance straightforward?
All the shops seem to stock Shimano or Shimano compatible bits, so I don't want to buy something that won't take a 'standard' chain, cable or cassette.
Yes, your analogy is perfect, it is just something to get used to insofar the shifting goes. However, SRAM's two big flaws are Elixir and Juicy brakes (the latter phased out by now) and the GXP crank/BB system.SRAM Rival on road bike and never had any bother with it. Not had experience of Shimano equivalent though so can't compare, or for that matter get confused with different shifting methods. Is there any comparison there with driving cars with indicator on left/right side of wheel?Just different and something to adjust to?
Yes,SRAM Rival on road bike and never had any bother with it. Not had experience of Shimano equivalent though so can't compare, or for that matter get confused with different shifting methods. Is there any comparison there with driving cars with indicator on left/right side of wheel?Just different and something to adjust to?
But the fact that the shifting boils down to quirks doesn't mean we don't want a passionate and rambling discussion about it. Preferably with religion-like zealot views, taking sides with the various nationalities involved and invent silly slogans. Nice examples are: Campagnolo wears in, Shimano wears out and, I'd rather walk that ride Shimano.
Me, I just remembered that sucky noise the SRAM Red cassette makes when riding. Typical of those noisy Americans.
