adunn01 said:
Not sure if it was your video, the one I'm talking about showed another cyclist safely passing a car in exactly the same strip of road which was apparently not wide enough for Mr "the sign says i've got priority so you must stop no matter how much space there actually is".
That another cyclist in front chose to take a risk that I may not choose to take, and he gets away with it, does not make it the correct decision. Sign says give way to oncoming traffic in a location which does not have, in my view, sufficient space to pass with a margin of error, then thats what the oncoming traffic has to do. Its my call, not the other guys, and if its safer to stop the traffic and then go around then thats the correct decision.
Could well have been one of mine; you're too passive if you believe that because someone else is in the gutter you should be too.
I'm by no means a passive cyclist, but there's a line between cycling in a manner that maintains your safety and taking unnecessary road positions just because we can. The driving standards in this country can be shocking, but too many cyclists hide behind this and use it as an excuse to 'put drivers in their place' when the drivers done very little wrong.
It isn't just because you can, its because its the safer location to be in. If that inconveniences someone else because they'd rather break the law than grant you safe space then thats their lookout. You really are a passive cyclist if you believe otherwise.
