rogerzilla
Dot and dab is evil stuff used by builders to save time and money. Metal self-drill Fischer plugs work for light to medium loads but must never be able to rotate. You sometimes have to snip the end off and drill a pilot hole if the air gap is quite narrow.
For heavy loads that tend to pull on the fixing, you have to go into the masonry behind. This raises the risk of crushing the plasterboard into the gap. Battens work for things like curtain poles, as they spread the load, but are useless in a shower. The ultimate solution is Corefix fixings, which look like wallplugs and screws but bridge the air gap with a rigid sleeve. They cost an absolute fortune.
