I happened upon this recently on my travels.
In keeping with what has become a depressingly regular sight, this appears to be another nicked bike mercilessly ridden into the ground by the city's burgeoning homeless population before being discarded when it finally became unable to carry on
I've checked the frame number and make / model against Bike Register and have got no hits, as well as putting a couple of "found" notices up on local FB pages and Gumtree. If you think it might be yours by all means drop me a PM with the frame no. and obviously if it matches you're welcome to come and collect it.
This poor example is in surprisingly good nick considering the abuse it's been subjected to; suggesting someone at some point cared about it. The only real damage to the frame is a couple of gashes on the RHS of the down tube and the paint seems otherwise very good (and resilient - I suspect due to pre-dating various bits of environmental legislation). Unfortunately the bars are bent, while the back tyre is completely shredded; totally disintegrating in places and having evidently caught on the mudguard at some point bending it severely. The bike has apparently still been ridden like this, which has pretty much shafted the rear wheel too
I've done a bit of homework and it appears this was a low-mid range offering from the '80s, touted as a general tourer or utility bike. The 57cm/ 22.5" frame appears to be gas pipe (none of your fancy Reynolds tube here) and the whole bike weighs in at a portly 14.35kg as received. It has a 2x5 drivetrain with 50/40 chainring, 14-28 cassette and sachs friction-shifter-based components. Oddly (?) the square-taper cranks appear to be a diminutive 165mm long. Wheels are 700x21c and chromed steel with 36 spokes. The bike's fitted with chrome mudguards, panier rack and kickstand, apparently as standard.
On paper this would make an excellent utility bike (for when I want to cover longer journeys / tackle greater gradients than on the ofo without having to worry about using one of my "nice" bikes) however looking at the cost of appropriate bits on ebay doing it up looks like it'll cost more than I can currently justify. Irritatingly I recently flogged a similar (but tattier) Notts-build non-Raleigh for very little money, whose wheels and bars would probably have gone straight on
Equally I love the idea of building up the old frame with newer 9/10/11 speed components with STIs and again recently sold my old Giant which would have yielded a wealth of 8sp parts because I thought I couldn't justify the cost and hassle of sourcing an approriate frame as well as storing another bike. What are people's thoughts on this route? I understand some will consider it sacriledge and I generally like to keep things original, but since it's not a particularly high end / desirable model (and needs some bits replacing anyway) I guess this is less of a concern.
So there we go. I'm not going to rush into anything currently; for now it can sit under a tarp in the back garden until I have a better idea of how to proceed.. so please don't expect an interesting project any time soon! I'm also not sure if I can manage with the frame as it's a little bigger than I'd like; I measured the reach and stack earlier and it comes in at a little larger and more aggressive than what I'm currently riding so it might yet get punted on, although I'd prefer it to be in working order even then.
In the meantime I'd welcome any more info anyone might have on this model and thoughts on the pitfalls on fitting newer components (specifically STI shifters) - I'm aware that the axle spacing at the rear should be 120mm while the current spec for 8sp+ rim-braked road bikes is 130mm... but I suspect I could spread the dropouts a bit since it appears to be boggo non-heat-treated steel. Can anyone tell me about bottom bracket specs on this sort of bike please?
Equally if you might have a suitable rear wheel / set, rear mudguard and / or bars that you want to get rid of by all means drop me a PM
