Small to small big to big
GrumpyGregry
Here for rides.
And the cassettes got wider and wider and cross chaining angles got greater and greater. On a 5 speed block the angle 'fully cross chained' was only 1.8 degrees.
And what about the wear? So little attention to the wear. It's not all about efficiency, you know, it fact that's the side benefit to sensible avoidance of cross chaining.
Did you get the lottery numbers right btw?
Yes, wear may be an issue. Is it a significant issue? Especially with modern chains designed to be laterally flexible?
Can someone explain why big-big is so much worse than big-small? The big chainring is lined up with the middle of the cassette so the maximum deflection in either direction is the same. If we should avoid the two biggest sprockets when we're in the big ring because the chain angle is too extreme then following the same logic we need to avoid the two smallest sprockets! Why then do they even make 10/11 speed cassettes when we can only use the middle 6?!
Tension?
The Big - Big requires a greater chain length than Big-Small
This is taken care of by the deralieur arm, but the chain is still at the maximum tension
Tim Hall
Crawley
Tension?
Surely the tension on the chain due to a well nourished cyclist giving it "some welly" trumps the tension due to various sprocket/chain ring combinations.
The system is under different stresses according to where the chain is on the cogs
The same input will put different stresses on the chain in different gears
Ajax Bay
East Devon
Back from a good ride in glorious weather.
the catalogue of my terrible shocking inelegance on a bike
Do tell us what is higher in the @GrumpyGregry (in)elegance on a bike stakes that might shock the sensitive.
I'm not suggesting cross chaining breaks chains btw, just wears them unnecessarily and reduces their efficiency: the latter I think you have agreed.
You 'lottery numbers' banality was not addressed to me, btw, which is just as well as I have never played the lottery (that's what clogs up the shop queues on Saturday and Wednesday evenings, parting people from their money for 'noble' causes)?
