jonny jeez said:
only kidding.
I've popped the pedals off and greased them up in the past, and generally scrub out the rear cassette and re-lube with wet lube every week or so.
You don't need to lube a cassette - you mean lubing the chain, right?
I tweak the rear meck to try and find the right sweet spot but still get trouble finding top gear, so either my gear cables or rear mech are in need of a little something.
There are three adjustments to worry about here;
Top Limit
Low Limit
Tension
If the mech isn't travelling far enough (with cable unclamped, it should sit over the smallest sprocket, pulling the clamped cable as hard as you can should move it over but no further than the largest) it's the limits that need setting.
If the shifter does not move the mech to the larger sprockets smoothly it's the tension.
If the shifter does not move the mech to the smaller sprockets smoothly that's friction in the cable/pivot points. (Remove the cable from the cable guides, lube with a drop of lightish chain oil between finger & thumb (weldtite's cheap stuff is fine) make sure to do the bits covered by the outers - slide the outers along to do this. Lube pivot points with a squirt of GT85.
I am guessing I need to look at the rear cassette, rear mech and possibly the front chain set (possibly the entire crank set as I get a little "creaking" at times")
Creaking could be anything from bottom bracket to seat post - think about when it happens (while pedalling, while riding on uneven surfaces &c).
I think you almost certainly need a new cassette. If you've never checked your brake cables over those 2,000 miles, now's the time.
