Exile
- Manchester
Riding home Friday night, after dropping in to the little ring to make a climb, I found I couldn't get back in to the big ring. Not a problem, half a mile from home so I spun the rest of the way, then put the bike away with the intention of fixing the problem over the weekend. It'd be a quick job, probably just the limit screw or cable tension. Weekend came, and I've just spent the last hour or so tinkering with cables, limits and mechs and I'm now at my wits end and think I need some advice before I do something drastic like turn it into a single ring at the front, or buy a new bike.
It's a Sora double shifter, and I can see that moving the lever moves the cage, but it just won't 'click' in to place, meaning I can get it to shift the chain on to the big ring (and, after adjusting limit screws, off the rings all together), but as soon as I release the lever, it goes back to the small ring. Prior to Friday things were fine. Any suggestions on things I could try to fix it, or what I can check to see if it is cream crackered?
