Don't lots of motor homes use this kit? Maybe have a mooch around their sites?
Ive got the flexi panel for now, so i can remove it easy in bad weather……Not on the shed but on my camper, as you 100w flexi panel and controller.
Rigid panels are better value apparently so if yours is this type probably better, get some airflow underneath.
What would you like to know specifically?
Sized the cables??? Tell me moreYes that similar to the set up on our camper, 2 x 125w panels and an MPPT controller.
It’s pretty plug and play although make sure you’ve sized the cables correctly.
Cabling is all uncluded in the package4mm as minimum (PV to controller) but the general logic says go as big as you can fit into the terminals.
Ideally then 6mm from controller to battery. And avoid too long a cable run.
Getting usb lights for now, straight from the controller, will then wire battery with inline fuse for added protection, will then run lights again through a small fuse box just in case and for added protectionTo be honest, fook all!
My controller is a 'dual ' one so can be set to charge both 'starter ' battery or 'leisure' battery in a % . You probably won't need this facility as you may only have 1 battery.
I would always go for 'warm' led strip lights as the White can be a bit bright.
I use a 110 amp leisure battery rather than a starter battery as they're designed for charging/discharging.
Yup thats the plan…….might even try and run an auto watering system for the greenhouse with it.Sounds like a plan, 1 fuse should be adequate between panel and battery 10a, close to battery.
Then just wire anything else you want to the battery via a fuse box as you've suggested.
This time of year because the Sun is low I'm seeing around 21 v from the panel and 13ish in the battery.
Do you have an inverter fitted too???Sounds like a plan, 1 fuse should be adequate between panel and battery 10a, close to battery.
The man cave has a tv and pc…….so i would want to run them off itI would avoid an inverter if you can, pretty inefficient use of that harvested leccy. Try to find 12v devices where you can
