*** SOLD *** 20"(ERTO 451) barely used front disc wheel & two tyres
PaulM
Portsmouth, UK
Hand built 20" (ERTO 451) front disc wheel, 28 spokes, Sun Ringle CR18 rim, Hope Pro 2 Evo hub (OLN 100mm). Includes 2 tyres, Velox rim tape and spare left and right spokes. Used for maybe 200 miles. Durano 28mm tyre is unused (wire bead), plus Schwalbe HS110 37mm tyre which is the tyre it was used with.
This is slightly larger than the more common ERTO 406, 20" wheel, although since the radius is only 23mm greater it will often fit disc forks made for the 406 size.
£60 including UK mainland P&P.
Photos: https://photos.app.goo.gl/d47v7pUHfAoqLiNPA
