Head unit
SD card with additional maps
Charging cable
1/4 turn disc mount
In perfect working order, the battery life on this Garmin is second to none, by far the best battery life I've experienced and even after entire days on the bike, the low battery warning hasn't been seen. Compatible with all the other Ant+ bits.
Its a used item with a few marks and rough edges but it's a brilliant, hard wearing reliable piece of kit.
Spec/Description below.
Providing navigation and performance monitoring, Edge 800 is ideal for touring, commuting, competitive cycling and mountain biking.
It has a built-in basemap and tracks your distance, speed, location and ascent/descent. Use it with an ANT+™ heart rate monitor¹, speed/cadence sensor¹ or compatible power meter² for a finely tuned analysis of your ride.
Edge 800's touchscreen display is rugged enough to stand up to the elements, yet sensitive enough to respond to the tap of your gloved hand. Switch training pages or pan and zoom the map with just a tap. The bright, sunlight-readable colour display is easy to view in all lighting conditions. Just don't let its good looks fool you - Edge 800 is waterproof to IPX7 standards and can withstand hard knocks and scrapes it might endure in mountain biking environments.
The aerodynamic Edge 800 has a carbon fibre construction and attaches to the stem or handlebar of your bike with the low-profile mount. A quarter-turn mount design holds unit securely and lets you easily swap it between bikes using removable, reusable bands.
Whether you're training for a century ride or competing in road or mountain bike races, Edge 800 helps you make the most of every ride. This GPS-enabled bike computer tracks speed, distance and elevation and has built-in mapping.
Edge 800 records your every move with a high-sensitivity GPS receiver that stays locked on to a signal, even under tree cover. The receiver features HotFix® satellite prediction to calculate your position faster, plus it has automatic time zone adjustment ideal for a European cycle tour holiday.
Features a sleek design and quarter-turn mount. For detailed post-ride analysis, mapping and the ability to share your ride, upload to Garmin Connect™
Unit dimensions, WxHxD: 2" x 3.7" x 1" (5.1 x 9.3 x 2.5 cm)
Display size, WxH: 1.4" x 2.2" (3.8 x 5.6 cm); 2.6" diag (6.6 cm)
Display resolution, WxH: 160 x 240 pixels
Touchscreen: yes
Weight: 3.5 oz (98.0 g)
Battery: rechargeable lithium-ion
Battery life: 15 hours, typical
Water resistant: yes (IPX7)
GPS-enabled: yes
High-sensitivity receiver: yes
Basemap: yes
Ability to add maps: yes
Accepts data cards: microSD™ card (some versions include a CityNavigator microSD card)
Charging cable
1/4 turn disc mount
Touchscreen: yes
GPS-enabled: yes
Basemap: yes
