***SORTED***Square-taper triple chainset/crankset, 50-39-30t, 170mm
byegad
NE England
Try SPA cycles. I'd be surprised if they can't help.
Chislenko
Does anyone have such a thing knocking around their spares bins? Ideally alloy. I can't go smaller than this due to limitations of a braze-on FD.
TIA
I have a spare 52-42-30 (done about a thousand miles) I wouldn't mind swapping for a low mileage 48-38-28 if you have such a thing.
ColinJ
Puzzle game procrastinator!
I was thinking that. I went that route when I 'triple-ised' my CAAD5.
580126
I went for 48/38/28 (and have since replaced the 38 with a 36) but all sorts of combinations were available. I just checked - the nearest they do is 50/40/30, if that is any use to you - £65. You might be able to persuade Spa to replace the 40 with a 38?
ColinJ
I've just noticed... You can choose your own selection of rings for an extra £15. (Presumably that it is to pay a member of staff to faff about swapping them round!)
PS And that the current version is a bit different to the one I bought, which has 5 visible bolts NOT 4.
Xipe Totec
Frrrg rrrrf yrrrr crrrnds
Just dug it out from the bottom of the box it's been in for the past 8 years or so - it's in good nick, no significant wear, a couple of little scratches , no heel rub. Looks like I even gave it a wipe before putting it away! Turns out it's a 175 (odd because the bike it came of was a 56 seat tube), & the replaced ring's a Stronglight.
No idea what it's worth - does £25 posted sound reasonable?
DCBassman
DCBassman
I'll give it a miss at 175, just a bit long for me. Many thanks though for digging it out. I will ipdate my want to say 70.
Steeler
Bristol
I've got a Stronglight Impact 28/28/48 chainset in pretty good nick - the middle and outer rings are pressed steel pretty much like the picture that Xipe posted. Oh, and it's 170mm. I'll post a pic if you're interested.
DCBassman
DCBassman
It occurs to me that I could transfer the rings onto my Ritchie cranks, same BCD. Is that kind of swap a thing? If so still interested!
