Specialized Allez Octalink Bottom Bracket - Which one?
JohnHughes307
Bexhill on Sea
I think My Specialized Allez is either 2015 or 2016 (I bought it 2nd hand late last year) and is fitted with the Shimano Claris Octalink Groupset.
I have recently started getting an annoying clicking noise once per pedal revolution which I think is coming from the BB. I've tightened everything I can think of but it is still there :-(
I have now ordered the 20 spline removal tool that I will need to extract the BB but I still don't know which replacement BB to purchase - can anyone help? Otherwise I will have to wait for the tool to arrive, then remove the BB to find out which one it is, then re-assemble the BB while I'm waiting for the new one to arrive :-)
Levo-Lon
It is almost definitely a standard 24mm BB Hollowtec.. Like this? Yes
View: https://m.youtube.com/watch?v=RVTEOzzNa_U
iluvmybike
Remove cranks and you'll be able to measure axle length in situ. Shell width is just measuring the width of the frame where the bb sits
J
JohnHughes307
Bexhill on Sea
OK - So I have learnt some things...
First, in case anyone looks up the thread, the Claris Specialized takes a 68 X 113mm Octalink BB.
Second, Cheap Bottom Bracket removal tools aren't as good as you'd like them to be. I had to sand the paint off to get enough purchase to remove the drive-side.
Third, I can replace bottom brackets although it wasn't as simple as it looked on you tube - it is all OK now.
Fourth, I have cocked up my indexing and it is going to take some tweaking to get it right again.
Fifth, the clicking wasn't the bottom bracket! :-(
J
JohnHughes307
Bexhill on Sea
Not yet, no. But you're right - I am much better equipped now in knowledge, tools and parts :-)
