xxmimixx
- a different place on earth...
Hi.
This model is the upgraded version with the full Tiagra set as opposed to the current 2011 model that only comes with the Sora. This is the equivalent of the current Allez ELITE. The bike is in excellent condition and well looked after, only done 800miles. Size 56 located in Kent.
Pedals not included. £450 ono
Frame: Specialized A1 Premium Aluminum, fully manipulated tubing, compact design, integrated headset
Fork:Specialized FACT carbon, carbon fiber legs, aluminum crown and steerer
Front Derailleur: Shimano Tiagra, 31.8mm clamp, bottom pull
Rear Derailleur: Shimano Tiagra, short cage
Shifters: Shimano Tiagra, 9-speed STI, flight deck compatible
Chainset: Shimano Tiagra
Chainrings:50/34 tooth chainrings
Bottom Bracket:Shimano FC-4500
Cassette:Shimano Tiagra, 9-speed, 11-25 tooth range
Chain:Shimano HG73, 9-speed
Pedals:Silver cage, black body, with toe clip and strap
Front Brake:Shimano Tiagra
Rear Brake:Shimano Tiagra
Brake Levers:Shimano Tiagra, 9-speed STI, flight deck compatible
Handlebars:Specialized Comp, 6061 alloy, short drop, ergonomic shaping, 31.8mm
Stem:Specialized Comp-Set, 3D forged alloy, 4-position adjustable, 4-bolt 31.8mm clamp
Headset:Specialized Mindset, 1-1/8 inch integrated threadless, steel cage bearings, 20mm alloy cone with 10 mm alloy spacer
Grips:Body Geometry Bar Phat, cork ribbon with 2.5mm gel padding
Rims: Mavic CXP22 rim, alloy triple-wall, machined sidewalls, 32 hole
Front Hub:Specialized forged alloy, 32 hole, sealed ball bearings, QR
Rear Hub:Specialized forged alloy, 32 hole, sealed ball bearings, Cassette, QR
Spokes:Stainless 14g
Front Tyre:Specialized Mondo Sport, 700x23C, wire bead, 60 TPI, Flak Jacket
Rear Tyre:Specialized Mondo Sport, 700x23C, wire bead, 60 TPI, Flak Jacket
Tubes:Specialized standard presta tube
Saddle:Specialized Comp Road, full padding
Seatpost:Specialized carbon wrapped, two-bolt clamp, 27.2mm
Seat Binder:Specialized alloy, 31.8mm
