The secteur elite has a sleeve with an offset center, as you rotate the sleeve it adjusts the angle. If you look at the back of the stem in the gap you will see some numbers that is the angle it is set at. Just undo the stem bolts and rotate the sleeve to adjust the angle. Also as has been said you can flip the stem for a negative or positive angle.
