junkie_ball
- Somerset
I recently changed my rubber and whilst doing this I installed some specialized inner tube (simply as this was all the LBS had at the time) Anyway when using my track pump to inflate them I have found the fit to be so tight I’m having to put my whole body weight behind me when removing the pump from the valve. This resulted in me ripping the valve out of the inner tube last night. I think it’s only a matter of time before the second tube goes the same way.
I have never had any issues with such a tight fit using other inner tubes with this track pump. Has anyone had this issue or know if specialized use a slightly bigger valve than other manufacturers?
