Spoke key.
Milzy
What’s a good value spoke key?
Do you tighten where the gap gets bigger between your pad? Righty righty, lefty loosey.
richardfm
Cardiff
I use one of these
https://www.sjscycles.co.uk/tools/spokey-pro-red-for-euro-us-spokes/
Spokes have a normal right hand thread, so to tighten a spoke you are turning the ripple anticlockwise as you look at the nipple/spoke towards the time.
This image illustrates it
https://bikebooboos.com/wp-content/uploads/2012/09/Spoke-tighten.png
You tighten the nearest spoke on other side to where the pad starts to touch the rim. That pulls the rim away from the touching brake block.
Tighten the nipple anti-clockwise when looking along the spoke from the axle. And only small turns of the spoke key at a time.
Adjusting an out of true rim with the wheel still on the bike is OK if in a hurry, but not really accurate if out of true at more than one point. It is rare on an old wheel when a rim is out of true only at one point.
You will probably make mistakes the first time.
figbat
Former slippery scientist
You should also ‘blend’ the spokes either side of the one in question, and loosen the spokes on the opposite side. It’s as much art as it is science. Twanging the spokes can give you a sense of tension and any differences.
For on-the-trail emergencies I have a valve cap on one wheel that fits spoke nipples (the other valve cap does valve cores).
Worth having Schrader valves for the convenient caps?
Milzy
Milzy
I know you say it’s rare on one spot but it’s a Hunt four season and it’s massive in one place. Prob from dropping off the kerb thinking they’re bombproof.
PeteXXX
Hamtun
My Crank Brothers multitool has a spoke key.
If it is massive in one place then it's likely to need tweaking on several spokes and could be tricky.
If it's out of true radially, with a flat spot, after dropping from a kerb it will be even trickier.
Good luck.
Big John
These are the sort I use to build wheels. I've got various coloured ones to cover the different nipple sizes. These are spoke nipple size specific. You need to know what spoke nipple size you have before buying one of these.
https://www.bikeparts.co.uk/product...2TKZ3iHWeBqvTqN8ph5zXO4zqoU5Jc94aAtbmEALw_wcB
To carry in your saddlebag when you're out you're better off with one of these. Then if someone you're with needs help and they have a cock eyed nipple size then chances are it'll fit, as long as they don't have an ebike. Then you need yet another tool to cover ebike spoke nipples.
https://www.sigmasports.com/item/Pa...3fnkVT7W3fOKRL-g747YwuP16E7JtpXAaAnCIEALw_wcB
Milzy
Milzy
What about the keys that show the tension on a digital display so you can make every spoke the same tension?
Big John
I didn't even know such a thing existed. Every day is a school day, eh?
Can you show us the link to one of these please? Or do you mean a spoke tension meter?
sevenfourate
Devotee of OCD
That’s slick. Love that. A pair you’ve bought, made, assembled or ?
rogerzilla
I have a Pedro's one I bought years ago. The 4-sided ones are best and you generally only need the 3.23mm/0.127" size for modern 2.0mm spokes (DT, Sapim).
