Hi, I hope someone will be able to help, as seen in the photo I have a very small crank arm/ tyre overlap it's not a big deal as the crank arm pushes over the tyre, but I would like to shave a couple of mm off the tip of the crank arm to give me clearance.
I'm aware that the SRAM Rival OCT is hollow but does anyone know for certain if the end surrounding the pedal thread is hollow or is it solid at that point allowing me to shave off 2mm? Thanks in advance
