bonj said:
oh,
WELL - if you *
must* go down that route...
To be fair Bonj it's really not rocket science and seems to have been made overly complex by the major manufacturers 'accidently' producing incompatible shifting setups. If there was no rear mech in between then cable pull would be a direct factor of sprocket pitch(width between sprockets). I know you may well know this but others may not, I certainly didn't until I did some homework. So I'm going to post my understanding and please correct if there are errors.
Bar Levers - STI=Shimano, Ergo=Campagnola & Double Tap=SRAM, all 3 are indexed which means they are a ratchet and release mechanism. Or each movement of the mechanism will pull or release a certain amount of cable. Some can pull or release various lengths to allow for multiple shifts. There is also a generic lever called Modolo Morphos which claims to work with any system, however reviews on this product are very unfavourable. Fiddly setup, poor quality and lots of phantom shift type issues.
Cassettes - this is the combination of sprockets at the rear, your largest sprocket(most amount of teeth), will be dictated by the cage length of the rear mech. Longer cage more teeth can be handled and vice versa. SRAM and Shimano have identical width sprockets and gaps between sprockets also the fitting to the freehub matches as well. Campagnola have a different freehub fitting and a 0.2mm variance in the pitch(space) between sprockets. The freehub fitting rather than pitch variance is the biggest hindrance. As 0.2mm per sprocket is a very small variance and a rear mech normally has some play allowance anyway, which is greater than 0.2mm.
Rear Mechs - these are a spring loaded pulley/jockey wheel system that the chain runs through. The cable pull from the bar levers is translated into movement of the mech and thus movement of the chain across the cassette. The mechs for the 3 manufacturers all differ in cable routing and geometry. This means that each requires a different amount of cable pull to effect the same amount of chain movement. Thus the levers and mechs from the 3 don't blend well together.
There are ways around it and some accidental matches, ie Campagnola 11 speed is meant to work with Shimano 9 speed mechs with no mods. Campag 10 speed is meant to work with Shimano 9 speed if you alter the cable routing at the Shimano mech. Search for Shimergo on CTC to see the article with all the mix and match results. There's also the Shiftmate from Jtek which you can route the cable through on the way into the rear mech. This is like an extra jockey wheel which translates the amount of cable being pulled by the lever to match that required by the mech. I haven't seen any work arounds for SRAM with other stuff, only the other two together.
Any more info on this stuff, or corrections, gratefully accepted
