Ajax Bay
- East Devon
I had put (and have left in situ) a chunky ziptie round the right hand chainstay, pushed right up against the bottom bracket shell. With the chain in the small ring, the ziptie gets in nothing's way, but if the chain tries to suck I hope that the ziptie will provide a tiny nudge 'down' to the rising chain and stop it (from sucking up into the FD cage).
This seems a good article: https://bikemagic.com/how-to/mountain-bike-maintenance/chain-suck.html
"Tooth-Wear, and Low-Stretch (New) Chains, and High Friction (eg Mud), when present in various combinations, cause the chain-ring’s bottom teeth to become loaded or overloaded by the chain’s pedalling tension, and also cause resistance to disengagement of the chain. The rear-derailleur spring cannot provide enough tension, and the chain does not have enough weight to disengage itself from the bottom teeth of the chain-ring. The links are carried up the rear of the chain-ring under continuing load …the chain “sucks” !!
Wear on the tooth’s pressure-faces (not burrs on tooth sides or thickened teeth) is the MAIN CAUSE of [ . . . ] Suck"
Article suggests (with rationale) that a new chain is more likely to suffer from this.
I think that this happens because there is a momentary reduction in tension the return leg of the chain as the RD cage spring takes up the slack (generated by a drop of 16 teeth (say) at the front).Chain suck happens when you change down also.
