Stem angle - Blowing my mind
Stu Smith
Lancashire
Basiclally I need or want my stem to be level.
The headtube angle on the bike is 71.5
What angle stem do I need to have the desired level stem?
Trying to work it out is giving me headaches...
mcshroom
Bionic Subsonic
It should be 90 - 71.5 so 18.5 degrees
Globalti
A couple of degrees too high or low won't be obvious when viewed from most perspectives though.
Check out Specialized Body Geometry stems, which come with a tapered shim for fine tuning the angle.
boydj
Paisley
Surely it's more important to have the bars at the correct height, which can be adjusted with spacers. Cheaper than trying to find a stem with an unusual angle.
