Fastpedaller
- Norfolk
Long story short....... I've been using a DIY gearchange comprising 'capuccino' mounts with Shimano bar-end indexed shifters for the last 12 years. They have given a good and easy change with hands on the hoods. Recently one of the detents on the RH lever packed up, and I don't seem able to get a replacement (only pairs, and expensive). I was hoping to dismantle it and effect a repair, but it's peened over so any attempt to repair will render it useless. It's 3x7 speed (8 will also work). I've replaced the RH shifter lever with a friction one, which works ok, but I confess the indexed gearing is easier to use. I have seen Shimano Tourney Brifters and they may be an option, but I'm pretty sure I'll need to replace my V-Brakes with Mini Vs to get adequate braking. Any comments will be appreciated
