Morning everyone,
I commute year round on my Cannondale Synapse (the wife doesn't go in for the whole n+1 thing) which has an ultegra 6800 groupset installed (a mixture of 32 - 52 miles per day). I'm really struggling to get good performance from my FD. I'm having (getting the LBS) to install new cables way too often in my opinion just to be able to change chain rings with any kind of confidence and it usually isn't long before I'm getting chain rub when the FD doesn't reach the limit screw, followed by not moving up to the large chain ring. This results in me having to manually move the FD. I had a new cable fitted a couple of weeks ago which lasted 8 days or so before it started struggling (admittedly it was day 8 of 9 of LEJOG). I took it back to the LBS for them to adjust due to stretching, but the mechanic said I've got a sticky FD. I try to keep it clean, give it a good spray with WD-40 if I've ridden the bike in the wet but it's still sticking. Is there a way of 'refurbing' it or is it just giving it plenty of cleaning and WD-40?
