Fair point, I shall have a good read around and then maybe ask advice. Currently pondering a HSBC FTSE 250 tracker through Hargreave Lansdown though
For a 'good read around' I recommend this
http://www.amazon.co...t/dp/0954809327
It's not a beginner's read, but his central premise is well set out:-
- not even the best fund managers can beat their benchmark consistently;
- they charge you in numerous hidden ways (bid and offer spread, management fees, trailing commissions etc) so that you cannot easily see how much you are being charged;
- those charges will erode your returns very significantly;
- you are being charged for something which is usually worthless, because in the long term they don't out-perform;
- you can easily become more expert than most financial advisers and their interests are not the same as yours.
John Kay's conclusion is that almost everyone would get the best returns by a) choosing a range of sectors which give a good spread of risk and b) within that sector, picking the ETF or Tracker which has the lowest TER [total expense ratio, a figure which they have to declare.]
HSBC have a good range of ETFs and Trackers. So do Blackrock and several other providers.
If you are going to invest, an ISA is a sensible vehicle provided you don't have to pay any extra for the tax wrapper. One of Gordon Brown's less publicised actions was to remove the tax benefit from dividends accrued in an ISA, so that for a standard rate taxpayer they have no advantage unless you manage to create an investment gain above the CGT threshold. There are several ISA providers who make no extra charge. [Hargreaves Lansdown's Vantage ISA is only free if you invest in funds i.e. not free at all, because of the arguments above and because commission is fed back to them by the fund managers.]
