mjr
- mostly Norfolk, sometimes Somerset
Has anyone else noticed that the street lights on Highways England's roads come on before the street lights on local council roads?
A lot of Highways England ones are newer and fitted with light sensors - a lot of the council ones are older and fitted with timers. For those with sensors, it'll also depend on the type of sensor fitted.
Different sensors, also the threshold for each sensor is unlikely to be identical. Also some light circuits now employ 'smart' lighting technology that allows councils to remotely control when lights turn on and off.
You are very lucky. I wish they'd do that here. Most of Cambridgeshire resembles Las Vegas at night - even the smallest of villages is stuffed with blindingly bright lights. It's a bit ridiculous really. Suffolk have a much more civilised approach to lighting, happily leaving many villages unlit. Perhaps there are fewer townies there moving to the countryside there then whingeing about the dark![]()
Agreed. We recently suffered an upgrade to stupidly bright, coupled with new lampposts that are several feet taller and now blast their light straight into bedroom windows. The company responsible will at least add inadequate 'baffles' to the lights which reduce if not eliminate the intrusion, but the situation is still worse than before. Some lucky side streets near us have no lighting, and I am not aware of any greater safety issue there.You are very lucky. I wish they'd do that here. Most of Cambridgeshire resembles Las Vegas at night - even the smallest of villages is stuffed with blindingly bright lights.
Agreed. We recently suffered an upgrade to stupidly bright, coupled with new lampposts that are several feet taller and now blast their light straight into bedroom windows. The company responsible will at least add inadequate 'baffles' to the lights which reduce if not eliminate the intrusion, but the situation is still worse than before. Some lucky side streets near us have no lighting, and I not aware of any greater safety issue there.
You could always get blackouts to go between your curtains and the glass, instead. Probably similar price and less chance of a criminal damage chargeI discovered that with a bit of elbow grease, a good shake of the column, would often switch off a lot of the old lights. That's sadly not the case with these new efforts. I'm fast coming to the conclusion that the only solution is a decent airgun!
