Stumped by IQ test: help from uberbrain needed
spire
To the point
While clearing out some rubbish, I came across a 10-question IQ test. I am a sucker for these and got distracted. To my dismay, I couldn't answer one of the questions.
Can anyone answer and explain?
What is the next number in this series?
1, 2, 3, 5, 7, 11, 13, 15,...
Primes. Next is 17, 19, 23....
Gixxerman
Market Rasen
Not sure if this is correct.
But if you take the numbers 1,3,7,13 the active sequence and ignore the 2,5,11,15 numbers.
The distance increases by 2 every iteration for the active sequence.
I.E. 1->3 = +2, 3->7 = +4, 7->13 = +6, so next would be +8 = 13+8 = 21.
I have seen these sequences before where only alternate numbers make up the sequence, and the other numbers are decoys.
That is the best I can do.
gaz
Cycle Camera TV
South Croydon
I've had a quick go, but it's late, so i failed. It's been a few years since i did my maths a-level.
I can't seem to get it to fit under any of the 3 types of number sequence; arithmetic, gemetric or fibonacci.
I'll have to re-look at my calculations tomorrow.
marinyork
Resting in suspended Animation
Logopolis
They are the so called cyclic numbers.
1 is coprime to itself and the coprime of numbers less than or equal to itself. 2 likewise. 3 is obviously coprime to 2 . 4 has 1 and 3 coprime to itself but 4 and 2 are not coprime so it is junked. 5 is coprime to 1,2,3 and 4 and 4 itself is coprime to 5 so that's all right. If you bother to look at the totient function you'll get all the other numbers including
15 and φ(15)= 8 are coprime.
16 and φ(16)=8 are not. 17 and 6 are. 18 and 6 aren't etc. Quite a few of them stick out like a sore thumb where the totient function is 1 less than n it is obviously coprime or where n is even and the totient function is also even it can be ruled out.
A much better way of doing it is in group theory and cyclic groups. The klein group is isomorphic to the dihedral group of order 4 which is not cyclic so this is not isomophic to the cyclic group of order 4*. So 4 is binned. If you read your group theory which people may or may not be interested in there are dihedral groups of order 2n for 4 onwards so all even numbers bigger than this are binned. If p is a prime number by another theory in abstract algebra then it is a cyclic group. To prove n is not cyclic it is merely enough to find a counter example of a group of order n that is not cyclic. This is time consuming for larger numbers but there are a dozen theorems to help out.
I agree entirely. I would go into more Klein theory but I haven't got the bottle.
:rolleyes:
ohnovino
Large Member
Liverpool
The answer is 666. They are the possible values of x that solve the equation:
(x-1)(x-2)(x-3)(x-5)(x-7)(x-11)(x-13)(x-15)(x-666) = 0
I tried this technique in a maths exam once, and the teacher had to concede it was right :tongue:
yello
back and brave
France
Sometimes such questions are easy if you know what you were looking for.
I did it myself; scanned the sequence for the usual suspects. I drew a blank but if I had had some other candidates up my sleeve I may well have been able to identify the sequence on sight.
Could I have worked it out anyway? Now there's a question! I suspect not but the bottom line is I couldn't be arsed anyway!
rich p
ridiculous old lush
Brighton
Marin, my old mucker, I am suitably impressed.
Totally and utterly baffled too but that isn't hard, so you get no extra credit for that. I also dozed off halfway through and I thank you for that.:tongue:
