Joe24
- Nottingham
Rant:
Took my frame into LBS last Thursday. Still in there. Only thing thats been done is the wheel is built up, but the hub wasnt checked in the frame before the wheel was built, which has annoyed me as the axel is seeming like it is too short
Went for the System ex hub, and all the bike shops around here said it will fit, just got to wack some 5mm spacers on the axle and wang it in.
I went into LBS at the start of the week when the wheel had been built and it was then that i got the guy to try it. There will be about 4/5threads that the bolt will tighten onto. Be slighlty more if the spacers are grinded down to 3.5 or 4mm. Took the spacers yesterday, rolled up after club ride and the guy is sitting outside(ok, his lunch break) drop them off in the shop and theres no bike in the stand. Cool, not busy, will be able to get it done soon. Rang up today, "been busy, not had chance to had a look at it, got 2 bikes before yours"
Fine. What i wanted to know is will the axle fit, couldnt be told.
If it int long enough then it will need a longer axle, and with it being sealed bearings it will apparently be difficult(how difficult, is it just remove the nuts from one side and it will/should slide out?)
Then, theres the time for him to be able to find the best bottom bracket for the chain-line. Which "could get expensive", not what i wanted to hear. Could be about 1 or 2 hours to do that.
Am i just lacking in patience at the moment? The fact i have nothing else to do is probably not helping. Was hoping it would be done by today as i cant/have little chance of picking it up tomorrow as i cant get a lift down to pick it up.
Should i go down tomorrow on my ride and chivvy things along if it isnt done, or just get some patience and wait till its done properly?
This is the problem with being off with nothing to do after a bike ride
