Deleted member 1258
Tried something new today: Ditched the lycra jersey and instead went with a ss base under a baggy t-shirt. Interestingly, it seemed a lot of drivers gave me a bit more space and passed a little slower than normal, although that I could be imagining. What I wasn't imagining was most of the fast-commute cyclists didn't bother passing me when I was cruising along, whereas when I'm in the 'proper' kit they can't get past quick enough. Did I become the cyclist equivalent of a Q-Car? Whatever the case, I really enjoyed the change and might try it out for a while, see if today was a one-off or the start of a trend.
Plus, it meant I didn't look out of place nipping in the shop to get the makings for tea.
I've always commuted in my work gear, steel toe capped boots, work trousers and a tee shirt, have done for over 30 years, the only cycling kit I wear is a cycle jacket when its cold, I rarely have incidents. I recon its likely to be because I'm a little more easily identifiable as another Human Being than I would be if I wore cycle gear and a helmet.
