twentysix by twentyfive
Clinging on tightly
- Over the Hill
Maz said:Has anyone ever suffered from headaches and stuff since they went wireless? Do the waves mess with your head?
I think there are two frequencies which get used. The modern one is at 2.4GHz and the older one at 11GHz IIRC. I haven't checked but the 11GHz had more limited range - presumably because there was more absorption in the moisture in the atmosphere. I would then expect persons near the 11GHz emmitter to get warmed up slightly - sort of microwaved. But the power is probably quite small and one would never notice really. At 2.4GHz I'm guessing that there is less water absorption so that should be safer.
Then there is the possibility of resonances with nerve signals in the body/brain. But I know even less about that.............
If you want to be fire proof - wire everything up.
