tdr1nka
Taking the biscuit
- SE London, Bandit Country
Is this where I admit to being good at remembering where others have misplaced things and lousy at doing it for myself?
Speicher said:I recently had to have a Police Check for the College. I am sure they said that each job that requires a Police Check means that a fresh check is carried out. (Something to do with the loop holes that were discovered after the Soham enquiry).
The new job you are applying for will therefore not be able to use the "old" certificate IIRC. If you cannot find your certificate, you might like to look into this further, it should not stop you from applying.
tdr1nka said:I think they want to know I've been checked in the past so that I appear less of an unknown quantity. The job is working with disabled adults and I think they're looking for as much background info as possible before giving me the job.
- I think I mentioned I'm looking at a P/T job working for a Forensic Mental Health Organisation (So working with Ex offenders who have substance abuse problems). tdr1nka said:Thank you AF!
I think it's more or less 'in the bag' they just want to check my references first, which as you say makes perfect sense.
Fingers crossed tho, it's a great job with a charity who facilitate cycling for disabled adults which has its problems(miles of red tape)but looks to be very rewarding work.![]()
(not at the same time, I hasten to add
tdr1nka said:And good luck to you too AF!
It really pays to work in an area where you can get to see real results from your efforts.
I'm about to tackle the next pile of offending paperwork.![]()
I FOUND IT!!!
Now mislaid the application form in all the mess.
What are you like!!!!?????
tdr1nka said:I FOUND IT!!!
tdr1nka said:I laugh in the face of absent mindedness and thrive on adversity!![]()
