Tea?
classic33
Leg End Member
Good morning from a :cold: :hello:
Stay cool:ohmy:
Owdo
If it's as bad as you're trying to make out, staying cool shouldn't be a problem. You just nip outside for a bit.
Further "heavy snowfall" in the early hours, then a wee bit of colder weather.
Result: white ground with patches of tarmac showing.
Morning??
Bobby Mhor
Behind You
Going by that it's warming up up there. Only 1.9 below freezing.
Sun here too, you've not moved down here!!
I'll stick to my own covid riven country...
Tea land is out my council borders..
It's got that bad I've an apre-covid bucket list
1. walk along Largs Prom avec un single fish
2. Pint of cold cider avec pub lunch at Kirkstone Pass Inn
I'm working on the rest..:laugh:
classic33
Leg End Member
Something to look forward to then. I'll try to remember to warn you if it gets serious.
Try he says!
Hogging the sun and the snow, shouldn't be allowed. What about the rest of us?
PaulB
Colne
It was snowing very heavily at 6.30 this morning when I went out for my run - but that turned out to be a mistake! It was too dark to notice that one patch of sloping grass had frozen solid so when I slid on it, there was no way to stop the momentum and it took me down, driving my knee into the rock-solid ground. It was a good job it was near the end and not the start of the run. Still, it's non weight-bearing which means cycling will be okay until it gets better.
567500
Mo1959
Ouch. I did that last winter. Apart from it being a bit ouchy, I tore a hole in my brand new 2XU running tights which was annoying!
classic33
Leg End Member
Hope it heals up soon, and doesn't put you off early morning runs.
